Topic: ARC: Switching between monitors?
Hey guys,
I've recently purchased the UFX+ and ARC bundle. Very happy with my choice. smile
I've hooked up my main monitors to 3/4 and an alternate pair of monitors on 5/6.
Everything works when I use TotalMix, but for now I have to go between these and lower the fader on one and then increase the fader on the other output.
How would I configure the ARC to switch between the two with a button? I just can't seem to figure it out.
Thanks in advance!
2 (edited by ramses 2021-08-02 08:59:06)
Re: ARC: Switching between monitors?
Assign AN 3/4 as Main Out
Assign AN 4/5 as Main Out B
On the ARC use Speaker B to toggle between Main Out and Main Out B.
Additionally you can
- set the volume now for both monitor pairs to the same level by using ears or a SPL Measuring Device
- create a fader group for Main Out / Main Out B
This has the effect, that you always will have the same volume when changing the volume on Main Out and toggeling to Main Out B and vice versa.
Took me a while to find the Assign button but that's it!
Thanks a ton ramses, much appreciated! smile
You're welcome, enjoy wink
