_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for 0:02:10 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-UPVFMC4
OS version: Windows 10, 10.0, version 2009, build: 19043 (x64)
Hardware: B550GTA, BIOSTAR Group
CPU: AuthenticAMD AMD Ryzen 7 5800X 8-Core Processor
Logical processors: 16
Processor groups: 1
RAM: 16331 MB total
CPU SPEED
Reported CPU speed: 3793 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 190,70
Average measured interrupt to process latency (µs): 18,909729
Highest measured interrupt to DPC latency (µs): 186,40
Average measured interrupt to DPC latency (µs): 1,244985
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 121,854469
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0,021476
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0,040301
ISR count (execution time <250 µs): 112287
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 213,483259
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 456.71 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0,021476
Driver with highest DPC total execution time: rspLLL64.sys - Resplendence Latency Monitoring and Auxiliary Kernel Library, Resplendence Software Projects Sp.
Total time spent in DPCs (%) 0,045129
DPC count (execution time <250 µs): 383040
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 0
DPC count (execution time 1000-2000 µs): 0
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: svchost.exe
Total number of hard pagefaults 20
Hard pagefault count of hardest hit process: 15
Number of processes hit: 3
PER CPU DATA
CPU 0 Interrupt cycle time (s): 3,133579
CPU 0 ISR highest execution time (µs): 121,854469
CPU 0 ISR total execution time (s): 0,838967
CPU 0 ISR count: 112287
CPU 0 DPC highest execution time (µs): 213,483259
CPU 0 DPC total execution time (s): 0,899860
CPU 0 DPC count: 355527
CPU 1 Interrupt cycle time (s): 0,764484
CPU 1 ISR highest execution time (µs): 0,0
CPU 1 ISR total execution time (s): 0,0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 10,038492
CPU 1 DPC total execution time (s): 0,000012
CPU 1 DPC count: 2
CPU 2 Interrupt cycle time (s): 1,596873
CPU 2 ISR highest execution time (µs): 0,0
CPU 2 ISR total execution time (s): 0,0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 12,903770
CPU 2 DPC total execution time (s): 0,001886
CPU 2 DPC count: 687
CPU 3 Interrupt cycle time (s): 0,993518
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 15,187978
CPU 3 DPC total execution time (s): 0,000519
CPU 3 DPC count: 212
<rest of cores remove, mostly idling>
