Topic: MADI RX in status switch between lock&sync every 2 sec.
   I connect my matrix Tx with digiface dante MADI in by bnc. It might be clock or something wrong, the status of digiface dante
always change every 2 seconds between lock and sync. I did not link the MADI out to my matrix. How does the single Tx works? Or should I connect digiface's out and in to matrix at the same time? Is there a clock resync between the matrix and the digiface , right?   How would the digiface know the right 48K clock from my matrix BNC signal?
Thanks!
BG,
XuGuo
Re: MADI RX in status switch between lock&sync every 2 sec.
Seems the device is running on internal clock. A two-way connection with the other device configured as slave would work.
