Topic: RME Hdspe MADI FX Digicheck error
Hello there,
I have two questions.
1) While using VST via Reaper (or other DAW) I get errors from time to time in the DIGIcheck for the option Bit statistics & Noise via the AES OUT L/R. I am using XLR cable for the AES Out. It happens on some presets and not others. The errors happen on the left/right channels of the Audio Data Bits and blink in RED(1) from time to time. Is this behavior normal?
https://drive.google.com/file/d/1XSawaT … sp=sharing
2) Can I use AES I/O and MADI I/O ports simultaneously with the internal sync clock from the card or I should purchase dedicated word-clock cables and sync all devices to a master?
