ADI-2 DAC FS: manual ch. 30.2 Analog Outputs
XLR
- Output level switchable +19 dBu, +13 dBu, +7 dBu, +1 dBu @ 0 dBFS
- Signal to Noise ratio (SNR) @ +7/+13/+19 dBu: 120 dB RMS unweighted, 123 dBA
- Signal to Noise ratio (SNR) @ +1 dBu: 117 dB RMS unweighted, 120 dBA
I understood you this way, that you have Auto Reflevel enabled.
If this is the case, then you have with a volume setting of 0 at the device: 0 dBFS = +19 dBu = SNR of 123 dBA.
Next I understood your usual volume setting on the ADI-2 DAC is betweeen -25 and -35 (dB).
What I did not understand is your additional remark: "with AutoRef ON at -5dBu" ... don't know what you mean by this.
Lets assume this was simply "a mistake" .. and that - with Auto Ref Level turned on - you use a volume setting of -25 - -35dB.
Two possibilities
a) use a fix reflevel or
b) let auto reflevel turned on and let it pick the best reflevel for you whatever volume (or EQ settings) you dial-in
I like option b), because then Autoreflevel also considers B/T and PEQ settings, which is not the case with fix ref level settings. With fix revlevel settings you could get distortion when having the volume set to 0dBFS and adding volume by Equalizer settings (be it B/T or PEQ).
You should not be too religious about SNR .. the values are on such a high level, that you should not hear any noise ...
But .. lets simply assume you would choose a fix Reflevel of +19 dBu and turn down the level down to -35, then your resulting SNR would be 123 - 35 = 103 dBA. Maybe not so cool.
See screenshot from Excel, that I created 4 u...
By this you can get a "feeling" for the different values and their relationship to each other.
https://www.dropbox.com/s/icxta1bdrove0 … S.jpg?dl=1
So please review the information that you gave
- whether you turned auto reflevel on and
- whether you listen with a volume set between -25 - -35
Or in other words, that I created the Excel correctly for you.
If all is fine, then I think you could e.g. keep Auto Ref Level on and use an Attenuator of -20 dB.
Then you can now dial-in a volume between -5 and -15 dB and by this
- the resulting volume will be the same like now
- but with a higher resulting SNR which will be in the range if 118 - 123 dBA
With kind highest SNR (of -123 dBA) at volume setting of -6 and -12 (dBFS) (if you did not use B/T or PEQ).
But this you won't hear and is irrelevant for the quality of audio.
Feel free to use any volume that you want.
