Topic: [Solved] DigiCheck NG + Babyface Pro: loopback activated but no signal
both TotalMix and DigiCheck show the connected Babyface as active. But somehow I can't get any signal into DigiCheck. I have a Behringer ADA8200 connected only to the ADAT In, because I only use one pair of speakers.
Babyface Firmware is up to date, DigiCheck v0.85 and 0.86 both show no result.
Maybe someone has an idea what setting I am missing? smile
https://tobiaskeil.com/wp-content/uploads/2021/10/Digicheck-NG.png
https://tobiaskeil.com/wp-content/uploads/2021/10/TotalMix.png
Re: [Solved] DigiCheck NG + Babyface Pro: loopback activated but no signal
In the Digicheck menu Options / Instrument 1 / Input selection input channels 7/8
In Digicheck hit F3 or goto: options -> input device setup. U can set it up there
@waedi: Thanks so much! I knew it was simple... big_smile wrong inputs in the individual instrument settings.
Now everything works as expected. Thanks again!
