Topic: Can't Internal Sync two cards above 48khz
I've just added a second RayDAT to my PC and am trying to use the internal sync facility to sync the second card to the first card. The first card is running at 96khz using ADAT1 as Clock Source. So, after connecting the three-pin cable, I have set the second card to Sync In and 96000hz. But the Input Status window for the second card shows "Sync In Sync 48khz". Why is it not 96khz ?
