Topic: TotalMix window not showing after driver update to 3.27 (babyface)
I just updated the my driver from the previous version to to 3.27 (for Babyface on macOS big sur). Neither the Fireface USB settings window nor the TotalMix windows appear when I plug in either of my two Babyfaces. When they are plugged in, I can manually run the "Fireface USB settings" program and edit settings for both Babyfaces. I can also manually run the TotalMix program and it appears to have macOS menu items but doesn't show any mix window.
TotalMix on macOS has menus for Totalmix FX, File, Function, Options, Window & Help. Everything under "Window" is greyed out.
If I try File -> New TotalMix Window, a "Function & Device Select Window" dialog appears but there are no devices under "Device Selection."
Does anyone have any ideas? Both Babyfaces are on firmware 225. Nothing is showing as "blocked" in the macOS Security & Privacy window.
Right now I can't use any Babyfaces!!
Thanks,
Michael
