1 (edited by Jperkins 2021-10-17 21:53:41)
Topic: Can't Rename Main Output In Total Mix
Obviously, at some point I was able to name my main output as "Avocet" because you can see it in this attached image, but for some reason in the latest version I can't rename it by double clicking on the name like I can with all the input input/playback/output channels.
Did something change so that this can't be renamed or am I missing something?
Here is a screen shot of the mixer:
https://www.dropbox.com/s/fkicz4eepjtra … M.png?dl=0
Re: Can't Rename Main Output In Total Mix
That's a user protection thing from making too much edits in crucial areas. You still can do so, via right click and opening the Channel Layout dialog.
There it is, thanks! I originally did it so long ago that I forgot about this method.
