1 (edited by georgecorbetT 2023-12-21 10:08:47)
Topic: Top 6 Best Laminate Floor Cleaner Machine for Your Home
Laminate floors have become more and more popular thanks to their elegant looks and budget-friendly prices. They use an extra layer of durable layer for more long-lasting use. However, laminate floors are sensitive to many types of liquid cleaner, high heat, and abrasive rollers.
Therefore, choosing the best laminate floor cleaner machine is important to maintain your floor's condition over time.
So, what is the right laminate flooring machine for your home? We review the top 5 best laminate floor cleaner machines today to help you make the right purchasing decision. Let's begin!
Check This Out: Best Rated Laminate Floor Cleaner Machines: Best Reviews For In 2023
Laminate Floor Cleaner Machine Buying Guide
Are you wondering how to keep your laminate floors looking bright and beautiful over time? We think the best way to maintain the floor's condition is to invest in the best laminate floor cleaning machine.
These tools are designed to remove the dirt and debris on the floor without soaking or damaging the laminate layers. In addition, some machines can clean different flooring types such as hardwood, tile, marble, and even carpeted floors.
Here are some things you should consider before buying a new cleaning device.
Laminate Floor Cleaning Methods
Since laminate floors are more sensitive and require extra care than the traditional hardwood floors or tiles, here are four main methods of cleaning suitable for laminate floors.
Steam Mop
Steam mops are the most popular and safest cleaning type for laminate floors. Steam mops can get rid of dirt on the floor by heating water in the tank and release steam that kills up to 99 percent of germs and bacteria. All you need to do is fill up the water tank, and the steam cleaner will take care of the rest.
Spray Mop
This type of machine sprays liquids on the laminate floors to help you clean tougher and heavier mess. The best laminate floor cleaner machine can have both spraying and steaming functions. In addition, some models include cleaning solutions, which makes cleaning more easier.
Dry Mop
This type of mop does not come with water or liquid. Dry mops are also known as microfiber mops. Dry mops can get rid of dust, debris, and pet hair, but they are not suitable for cleaning greasy stains or stuck-on spots.
Spin Mop
A spin mop is similar to a dry mop, except they come with a spinning head to help pick up more dirt. However, the spin mop does not use water or cleaning liquids, and they are not good at picking up stains or greasy messes.
Vacuum Cleaner
If you want to use your vacuum cleaner to clean laminate floors, you should consider the Shark DuoClean with the extra soft brush roll suitable for delicate surfaces. Please keep in mind that vacuum cleaners won't sanitize your floor with heated water or cleaning liquids, but they are great at picking up large bits of debris.
We highly recommend that you use a steam mop for laminate floors because it is safe and effective at picking up dried dirt and stuck-on stains. However, you could also buy a dry mop and add water to the microfiber pads as you clean to make it easier.
How to Choose a Laminate Floor Cleaning Machine - Pro Tips
  • It is important to choose a machine that is gentle on the floors. For example, avoid using abrasive cleaners or bristled roller brushes on your laminate floors.
  • Avoid using wet mops as moisture could damage the laminate layers.
  • Avoid waxing or polishing your laminate floors.
Top 6 Laminate Floor Cleaner Machines in 2021
1. Editor's choice: Bissell SpinWave Powered Hardwood Floor Mop 2039A
This powered mop is one of the best laminate floor cleaner machines on the market. It is safe for cleaning on laminate floors, with more power than a regular steam mop. We are surprised at how many stains the Bissell SpinWave can pick up from the floors.
The Bissell SpinWave 2039A comes with soft touchpads to avoid damaging your hard floors while cleaning. We love the on-demand spray feature where it lets you control how much cleaning solution goes on the floor.
The mop pads are washable and reusable, which saves you the recurring costs of pad replacement. In addition, the Spinwave provides excellent maneuverability thanks to its lightweight and swivel steering cleaning head.
2. Runner Up: Shark Steam Pocket Mop S3501
The Shark Steam comes with a lightweight and modern design. It features  two-sided cleaning where you can use both sides of the mop cleaner head. The Shark S3501 can tackle up to 99.9 percent of bacteria, germs, and allergens in your home. To activate the steam, you pump the handle five to ten times.
3. Best for Heavy-Duty: McCulloch MC1275 Heavy-Duty Steam Cleaner
If you're looking to tackle heavy-duty tasks, the best laminate floor cleaner machine is the McCulloch MC1275 Steam Cleaner. This machine can remove grease, stains, and grime from multiple surfaces such as laminate, hardwood, tiles, ceramic, granite, and more.
There is a 48-ounce water tank that takes eight minutes to heat up. The McCulloch also comes with various helpful tools for the best cleaning experience: a floor mop, brass brush, nylon brushes, scrub pad, and more.
4. Best Robot: Roborock S6 Robot Vacuum
The best robotic vacuum we've tested for laminate floors is the Roborock S6. This model provides superior cleaning performance on bare floors like hardwood, laminate, tiles, and more. In addition, the Roborock S6 comes with a mopping attachment tool to remove stains and wet messes.
5. Best Traditional Mop: Professional Microfiber Wholesale 18'' Mop
If you already have a vacuum cleaner and don't want to spend big bucks on another steam mop, you can get a regular mop for your laminate floors. By far, this is the best standard mop we've seen in the market. Two microfiber pads attach to the main unit. The cleaning path is 18 inches, which is suitable for cleaning large spaces.
6. Best Vacuum Cleaner For Laminate Floors: Dyson DC65 Multi Floor Upright Vacuum
The best vacuum cleaner for both carpet and laminate hard floors in our list is the Dyson DC65 upright vacuum. This premium machine can pick up more dirt and pet hair than you've ever imagined.
In addition, the Dyson DC65 is one of the most powerful among other competitors in the same range. If your family members have asthma or other allergic conditions, the HEPA filter can trap up to 99.97 percent of particles inside the machine.
How to Clean Dyson Vacuum Cleaners in Easy Steps
Step 1: Prepare the tools needed to clean your Dyson vacuum cleaner. You might need a pair of scissors or knives, a flathead screwdriver, water, dish soap, and a paper towel.
Step 2: Unplug the machine from the power source
Step 3: Empty the dirt compartment.
Step 4: Remove the foam filter and run it underwater. Squeeze the sponge gently until the water is clear.
Step 5: Turn the machine upside down. Use the flathead screwdriver to detach the roller cover. Then, use scissors or a knife to cut any hair that might be wrapped  around the roller.
Step 6: Rinse the canister and wash it with soap. Check with the manufacturer to see if it's okay to use soap for your model.
Step 7: Leave everything out to dry completely. We highly recommend that you leave it all out for at least 24 hours.
Conclusion
Thank you for reading our laminate floor cleaning machine reviews. Share this with your friends and family members. Let us know if you want to add anything in the comments section below.
Re: Top 6 Best Laminate Floor Cleaner Machine for Your Home
You tried the latest driver 3.27? You use the latest macOS? If so then you need to wait until Apple fixes this. The latest beta is already a step into the right direction.
