Topic: Bit Test
Hey I was just running bit test with my new RME ADI-2 Pro FS BE. I have it connected via USB to my Mac Mini. I used Quick Time and played the files back at full volume.
When I play the test files, none of the files were passed correctly. I got only these passed with following info:
441_24_adi2pro_bittest 4s -> Showed passed message as 16 bit
441_32_adi2pro_bittest 4s -> The screen flickers saying it passed as 16/24 bit
48_24_adi2pro_bittest 4s -> Showed passed message as 16 bit
96_24_adi2pro_bittest 4s -> Showed passed message as 16 bit
96_32_adi2pro_bittest 4s -> The screen flickers saying it passed as 16/24 bit
192_24_adi2pro_bittest 4s -> Showed passed message as 16 bit
192_32_adi2pro_bittest 4s -> The screen flickers saying it passed as 16/24 bit
Are the results correct of why the unit does not pass the test files correctly?
Edit: ADI-2 State Overview shows that the AES input is 16 bit. Shouldn't the UFX+ AES output be 24 bit? I also tested using Optical SPIDF and it says the output is 16 bit, too. Strange.
