Topic: RME Fireface UC setting not Open
Hey there,
my Fireface uc work fine, total mix as well, but I'm not able to open fireface setting to change buffer size and ...
I tried all the possible solutions but doesn't work.
I have the latest driver, I changed the USB Cable, In task manager, fireface setting and total mix are enabled. My interface is on PC mode because I use windows 10. I also gave access manually through the firewall. I really don't know what I can do.
when I click on the application, I see in task manager it is open but I can't see it.
that would be great if you can help me with it.
