Topic: Fireface UC, UCX and UCX2
I have a question regarding the evolution of small firefaces.
After a long thinking I decided to buy the Fireface UC. I am very happy with it and have never seen such a powerhouse and brilliant software. Everything about the Fireface UC screams excellence. I am very satisfied and intend to keep this little treasure for a long time and I cherish it every day.
But sometimes still, I get no sleep over what i might have missed out with the UCX or the UCX2. I know that there is eq, reverb, and compression on each channel since UCX, that UCX is class compliant and UCX2 has Durec and is the highest evolution with even better specs and even lower latency.
Is there someone out there who has two or more of these devices and can say, that one is better than the other in terms of mic preamps and sound quality? Not only from a technical perspective (because they surely are), but in terms of: "Wow, when using these interfaces, compared to the other interface, this one completely blew me off." Especially considering sound and mic pres, if they capture voice and guitar even more accurate and make everything sound even better and give you more detail while listening to your recordings.
Re: Fireface UC, UCX and UCX2
You won't hear a difference at inputs and outputs. While the mic preamps are different circuits, they are all transparent. Differences are mostly found in the features available and some tech specs.
Now in some situations that might indeed make an audible difference. For example when you want to use a low impedance, insensitive headphone at highest volume. The old UC with 30 Ohms output impedance can not compete with the new 1 Ohm, as the 30 Ohms already eat some of the needed power. That said it can't compete with the ADI-2s that deliver a lot more power anyway. There will always be specialized hardware/devices that can do something better, but also cost a lot more money.
Other than this phones example it is hard to find further ones that easily showcase noticable differences in the myriad of applications the UC and UCX II are able to support.
3 (edited by ramses 2021-10-30 10:53:38)
Hi Fritzi,
device comparison excel
perhaps my Excel spreadsheet can help you find differences that might be of particular importance to you in your decision-making process. Everybody uses his interface in the recording area a little differently, so that there can also be different focuses and needs, for example pure recording vs. playing via virtual interfaces, see: https://www.tonstudio-forum.de/blog/ind … B-MADIfac/
Direct link to the Excel: https://www.tonstudio-forum.de/index.ph … -04b-xlsx/
UCX II - summary of changes
Please read also my summary, that I posted after the introduction of the new UCX II as it highlighes changes and improvements: https://forum.rme-audio.de/viewtopic.php?id=33222
The list of additional / upgraded features is very long between UC / UCX and UCX II.
There are now several possibilities...
a) I am satisfied with what I have.
b) There are a lot of improvements and additional features, I just have to have that.
c) I wouldn't necessarily have to upgrade, but I would like to counter-finance by selling my UC while it still works and doesn't age much more to get the highest possible resale price (~€600 should still be possible), but would then have to pay around 1299-600 = €700 extra.
d) If I already invest €700, then the jump to other solutions is also not far:
UFX II: 1879-600 = €1279
UFX +: 2198-600 = €1598
e) or integrating an ADI-2 DAC FS or ADI-2 Pro FS R BE into the current solution:
Keep UC + ADI-2 DAC = €966
Keep UC + ADI-2 Pro FS R BE = €1699
More options - Integration of ADI-2 DAC or Pro FS
Regarding last option e), see also my blog articles about:
1. The integration of an ADI-2 DAC/Pro into a RME environment:
2. The different models and interesting features of ADI-2 DAC/Pro:
https://www.tonstudio-forum.de/blog/ind … ses-EN-DE/
Some advantages of the ADI-2 Pro
The ADI-2 Pro I would recomment over the less expensive ADI-2 DAC model for the following reasons:
- to have two DAC chips so that you can run both, monitors and phones at different volumes
- to be able to make headphone comparisons which need two phones outputs
- to have a SRC (sample rate converter) in the setup which can become very handy when e.g. connecting devices which can not read the clock rate from your environment or have a fix clock (like e.g. a DAT device)
- to be able to connect the ADI-2 Pro not only through ADAT/SPDIF but also through AES, this keeps your recording interfaces ADAT ports free for other expansions (Preamps, AD/DA converter, link to HiFi as Monitor B, ..)
- to also have high quality analog inputs
- to have also digital outputs when needed, then you can also use the feature dynamic loudness on digital outputs if needed.
- supports the four typical studio levels
ADI-2 DAC/Pro - DA-Filter Selection
One of the unique features of ADI-2 DAC/Pro "high-end converter" compared to the "recording interfaces": with the ADI-2 DAC/Pro you can select different D/A filters of the DAC and maybe have the same findings as KaiS, that the Slow D/A filter gives also you the best listening experience when it comes to certain details of audio playback:
https://forum.rme-audio.de/viewtopic.ph … 68#p177168
It gives you the best possible quality using current equipment and is a well basement if you should intend to invest into better monitors / headphones in the future. If you check such devices at home, then you have already a solid basement in the ADI-2 DAC/Pro for best D/A conversion.
If money is no objection
Combination of UCX II and ADI-2 Pro FS R BE: 1299+1699=€2998
The UCX II as recording interface gives you already a lot that also UFX II would give to you in terms of quality and features (analog section, mic and instr inputs, Autoset, DURec features, FX, Class Compliant mode, Display ...).
The ADI-2 Pro FS R BE is the ideal companion to make the good even better.
To sum up
The options reach from improving your recording interface up to getting the best payable AD/DA convertion on the market to improve your monitoring section with an ADI-2 DAC or Pro, where the ADI-2 Dac/Pro models can also act as kind of monitor controller to have ultimate control over the end-volume of your setup and finally to have the best solution for monitors and phones (kind of "payable" end-game here).
Just use and enjoy until you need a new one. There will always be something newer round the corner with more features no matter what you get.
5 (edited by ramses 2021-10-30 13:41:04)
I think not to upgrade because "there will always be something new" is a bad argument. Either you need an upgrade for some reason (whatever reason, tastes and demands are different) or you don't.
But there are other things to consider as well: if you plan to upgrade, do it immediately while the device is still working.
This is the only way you can benefit from the high resale prices that RME devices achieve on the used market.
Depending on the age of the device, there is also a certain price range.
So why wait for the device to get older? It only loses value and the risk of a device defect increases.
In the event of a device defect (be it due to aging or damage) you would not get anything in return.
Repair is an option, but repair costs are usually quite high and would only significantly reduce the resale proceeds.
That's why I've chosen my answer carefully and listed options, some of which he may not have thought of at all, including the option to stick with what he currently has.
I also made the personal experience that good instruments, devices, additional features can be very motivating and inspiring for the work and make operating / using an environment easier and more fun.
6 (edited by illumina 2021-11-14 18:02:50)
Hi Fritzi,
Hello! Apologies for your time but you seem well educated on the matter-
If i have a Babyface Pro-FS right now, would there be any mild change in converters with the UCX II?
I really want the DUrec feature and will still use it more for that reason but i’m curious and my brain is fixed on knowing spec even if i would likely not hear a few DBs lost / gained in s/n or through preamp impedance smile
7 (edited by ramses 2021-11-14 18:29:48)
It's of no big importance which DAC chip they actually use.
RME devices are all known for their transparent non-colorizing sound.
A few dB difference here or there are meaningless.
The different RME products have a different feature set.
Better concentrate on the feature set and the type and amount of I/O ports, that you need for your work.
If you want DURec then choose between these recording interfaces: UCX II, UFX II, UFX+.
The larger / more expensive recording interfaces support more reference levels on inputs and outputs.
The more reference levels they support the higher the SNR over a wider range of volume.
If you want best payable ad/da conversion coupled with a lot of nice features, then get an ADI-2 DAC or Pro FS for your monitoring section. There you can also choose between different AD and DA filters.
If you have a very nice room and speakers then you can potentially also hear nuances like KaiS described in his posting:
https://forum.rme-audio.de/viewtopic.ph … 08#p157808
I described here in my blog articles:
- About the ADI-2 DAC/Pro differences and features
- how to integrate the ADI-2 Pro FS into your setup
The ADI-2 DAC/Pro are designed as converters. So it makes sense to combine them with a recording interface to get routing capabilities of TM FX as well.
If you primarily need DURec, then it's best to focus on that and to keep costs low .. (depending on budget).
But if you also want reference grade AD/DA conversion, coupled with very useful features, then the combination of recording interface and ADI-2 Pro FS is simply the best device combination.
8 (edited by fritzi 2021-12-10 14:43:24)
So i tried out a few things today with my fireface uc.
I had a cheap dac, with which i tested the spdif and coax output of my fireface uc. I wanted to see what difference it makes when i use a different dac which has no pristine audio quality. I routed the output of my fireface uc as well as the microphone to spdif so i can hear myself on the cheap dac but still use total mix fx to calibrate mic and output and stuff.
I went into my daw and tried mixing and i could not hear a thing. Everything sounded the same. Is it correct to assume based on this experience and the suggestions you provided that like with the better converters in the fireface uc which offer a way better listening experience than a cheap dac, that the even better converters on the ADI-2 Pro fs would offer even more critical listening for better mixing if you connected it to the fireface uc and listened on the adi-2 pro fs?
I saw that some units concentrate more on better conversion, an audio interface has additional costs for each mic input or output, right? So even when you connect and ADI-2 to the fireface uc, would it sound way better? Is the example with low impedance headphones only one case where the fireface uc is worse and it is equal in all other cases or does the 1 ohm output combined with the other components of the adi-2 or adi-2 pro fs provide superior sound quality?
I don´t quite understand this, forgive me for being a noob, I am trying to figure out how everything works. I thought that the higher impedance, the more current you need to power the said device. So if the UC has a 30 Ohms impedance and the new one has a 1 ohm, the headphone output needs far less current to be powered, i understand it up to here.
But why is it worse when using low impedance, insensitive headphones at highest volume? Because I thought the higher the impedance on the headphones, the harder it is for the interface to power it. I can notice this when I plug in my beyerdynamic 990 pro at 250 ohm, i also have the hd 58x at I think 150 Ohm. The beyerdynamic 990 pro needs a lot more gain on the headphone output, but sound more refined.
Does the quality of the music deteriorate if the headphone output has higher impedance or is it equally good, just you won´t be able to power really high impedance headphones with, let´s say 500 Ohm or so and you can do that with rme fireface ucx2?
10
High impedance headphones don't need high power (or lots of current), they need a high voltage! Both UC and UCX II can spit out up to +19 dBu at the headphone output, so drive these high impedance headphones without any problem. No matter if 1 or 30 Ohm output impedance.
11 (edited by fritzi 2022-01-24 02:00:06)
Ok, thank you very much, I always wondered about the Fireface UC, if I were to hypothetically connect a shure sm7b to it, would the gain suffice? Because I saw in the specs that fireface ucx2 and the ucx have higher gains for the microphone inputs. Which gain would suffice for the sm7b? Does the UC have enough for it, people say the shure sm7b is very hungry for gain and I think the UC also has lots of it. I saw a device named fethead or cloudlifter which is used for this.
12 (edited by ramses 2022-01-24 07:39:35)
The UC has already a much better gain range compared to other consumer interfaces.
Difficult to say as much depends on the strength of the input signal.
So try it out, if I read correctly you have the UC, so use it ...
If it doesn't work, well then try fethead, cloudlifter. Not sure whether you really want to upgrade to the UCX II because of that.
On the other hand, the UCX II is very exciting and offers a lot more features, see https://forum.rme-audio.de/viewtopic.php?id=33222
