Topic: Cannot get 4 x RME devices to sync/lock/clock!
Hi i cannot seem to find a way to sync the devices below:
Digiface AVB - Connected to server via USB3 to clean audio in LiveProfessor  and back to M-32 DA Pro
12Mic 1 - 12  mics to go to DigiFace AVB
12Mic 2 - 12 Mics to go to Digiface AVB
M-32 DA Pro - recieves clean audio from DigiFace and outs as stereo. ( 16 Pairs )
I would like to know how do they all sync to a master clock. i tried a few options,.. setting Digiface as input stream 1 and internal, and the others like wise. i always get red on the chosen clock apart from internal  in all units. i still dont have a signal coming from the 12Mic1 to the DigifFace AVB. i can see the audio in webremote, the connection to avb is visable but the AVB1 out is orange color.
I also tried HIVE 1.2 and set also from there. but no luck. Any tips to get this setup working please?
Re: Cannot get 4 x RME devices to sync/lock/clock!
Ensure that the stream formats and sampling rates match on talkers and receivers. The most common format is 8 Ch. AAF. Is the switch you're using AVB capable?
-Max
