Topic: The ABC's of ADI-2 DAC VOL Control
I know nothing about audio-engineering. I am a programmer. I tried reading through the manual without much success (have already read page 63 - didn't understand much). I find the vol control on the ADI-2 very interesting, and I was hoping you can help me understand how it works. I feel that I don't understand the very basic concepts so I can't even being to understand what is laid out in the manual. I hope to learn these concepts - it is pretty interesting...
Before my questions here is my setup (as a way to provide context - sorry if it is not helpful):
* PC hooked up to ADI-2 DAC via USB
* ADI-2 DAC connected to (integrated) Hegel 190 via balanced output
* (not sure if this helps) but I have atc 40 (passive) speakers
When I adjust the main volume control on the ADI-2 a couple of things (that I can see) start to happen:
* dbr measurements changes in +/-0.5 steps
* dbu measurement changes in steps of +/-6 (at certain dbr thresholds)
WHAT is DBR:
* I learnt this morning that decibel can either be an absolute value or express change in value. I assume dbr is displaying change in value.
* What does 0 dbr signify? Does it mean that at 0 dbr the DAC is not changing the volume and the signal is just being passed to my amp? or 0 dbr is the loudest level before distortion kick in?
* Currently I have it set to -15 dbr...what does that mean? Does that mean the DAC is changing the volume to less than the reference setting?
WHAT is DBU:
* Regurgitating what I've read dbu relates decibel to voltage...simply put higher dbu means more voltage?
* if dbu describes the relationship of decibel to voltage then why doesn't the dbu change (in 0.5 steps) as I change the dbr (in 0.5 steps)?
* In the manual they mention that there are 4 discrete dbu settings to realize full dynamic range. I listen mostly to classical music, and in orchestral works the dynamic range can be large. Is there an optimal dbu for balanced output & my-amp?
What is the best way to set & change the volume for the system?
* Since I'm using RME as a DAC, my amp is just receiving analog input, so (I am guessing) the amp's vol knob controls how much power is sent to the speakers. But changing the vol on the DAC also effects how loud the final output is...
* What is the best way to set & change the volume for system?
* Should I set the dac vol to dbr/dbu that is 'optimal' for my system, then use the amp vol control to adjust the volume level?
Thanks in advance for your patience and help.
