Topic: Thunderbolt expansion card
Hi!
I'd like to connect a UFX+ to my daw but I don't have a thunderbolt port on my motherboard, so I need to choose a pcie expasion card to add one.
Can I use anything I find or I need to be careful of the chipset like in the firewire days? Any known recommended suggestions?
Nb: I'm aware I can use usb2/usb3 but these ports are all used already.
Thanks!
2 (edited by ramses 2021-11-15 07:34:49)
Re: Thunderbolt expansion card
As an alternative, get an USB3 expansion card, then you do not even need a computer with TB support on Mainboard / in BIOS.
With USB3 the cabling can be even 1m longer compared to TB (3m instead of 2m) and it's all less expensive.
Sonnet card with FL chipset is recommended.
https://www.sonnettech.com/product/alle … 4port.html
Chipset:  Fresco Logic FL1100EX
Very good point, that's exactly what will happen! Thanks a lot for your help!
4 (edited by alex128 2021-11-15 07:32:13)
You can get it really cheap $12 on AliExpress, though I assume it would be the basic version
I bought mine from Fovore at AliExpress, Fresco 1100 but haven't tested it yet.
