Topic: [Solved] ADAT very low signal in one channel.
my problem is with adat:
I found this issue when i was trying configure with Cranborne Adat500 product.
I am using together with rme ufx 2.  FOR SURE signal which arrive to rme with adat from out-slot number 7 is lower around 80 procent. I was trying with full reset of totalmix from rme. I have no idea what is this...
I had already sending UFX to service once because one of inputs had a problem. Luckly i had still warranty.
Generally-i dont underestand why channel numbner 7 receive very low signal via ADAT.
Let me know what you think about.
Grazie
Marcin
2 (edited by waedi 2021-11-15 05:01:48)
Re: [Solved] ADAT very low signal in one channel.
You have two adat inputs on the UFX ll, can you check both ?
Can you reproduce the issue by the UFX ll-only with a cable loop test ?
A toslink cable from out1 direct into input 1, sending a signal to output adat 7/8, monitoring the input adat 7/8.
When the signals are correct same amount, then the issue was produced by the other device Cranborne Adat500.
Yeah, great idea, i did it-i found it...not RMER issue at all.
Grazie Waedi
