Topic: RME Madi Router with SoundCraft Vi 6
I’m using RME MADI Router to convert Madi Optical to Madi Cat5.  Exactly I want to convert Madi Optical from Soundcraft Vi 6's Local Rack to Stage Box's Madi Cat5.  But they can't connect to each other, specifically the word clock can't sync with each other and I also don't see the clock signal from the Madi Cat5 port.
How can this problem be solved?
Thanks for helping!
Re: RME Madi Router with SoundCraft Vi 6
Soundcraft's MADI implementation is incompatible (proprietary) with the one on the MADI Router. To the best of my knowledge it is not even based on Ethernet.
The problem can therefore not be solved.
Best regards,
Max
Best regards,
Max
So it can work with Madi Cat5 port on Digico?
No, this doesn't work with other devices, sorry.
