Topic: volume control ARC USB on input 1/2 possible?
Hi everyone,
Short question: Is it possible to assign one of the buttons on the RME ARC usb to control the volume fader of inupt 1 and or 2?
To clarify, I'm not talking about the gain knob, but specifically the volume fader that enables me to control the volume of the direct monitoring of the input.
Any definitive answer or help is welcome. Thank you smile
Best,
Afroham
2 (edited by waedi 2021-11-21 10:01:28)
Re: volume control ARC USB on input 1/2 possible?
No.
You can do some configuration in Totalmix with a fadergroup AN1/2 plus main-out.
And btw the volume fader of an input channel does not control direct monitoring unless the routing is active to the output channel where your monitoring is and there you also can direct control the fader of that output channel.
