Topic: HDSPe AIO
i have an old adapter chassis to connect my hdspe aio card to a laptop but the internal fan isn‘t working anymore…do you know if the hdspe aio card gets really hot under load? do you think i could use the chassis and card without a fan?
Re: HDSPe AIO
The AIO card does not get hot nor draws a lot of current. Fans are not needed, even for the adapter chassis itself, unless you have more than one AIO in use.
3 (edited by Scheffkoch 2021-11-30 12:10:33)
Re: HDSPe AIO
…thanks for your reply!
…i reckon this goes also for the old hdspe pci card (the one to connect a multiface), correct? (since it‘s only a „connector“ and the math is done inside the multiface)…
Re: HDSPe AIO
Yes.
