Topic: 16bits
Whatever the source, I never get a signal better than 48 kHz and 16bits either with CDs and bluerays or streaming (amazon HD) with a coaxial source
Maybe you should question your source device ... can it send higher than 48/16?
Yes it can
Sorry. First thank you for your answer.
As digital sources, I used a marantz UD9004 and a cambridge audio 752BD.
May you tell what your device is ?
I use these sources with the adi da
Do you mean the ADI-2 DAC FS ?
adi da does not exist.
If you play a CD, it is CD format 16/44.1.
Try streaming music which is 24/192kHz.
