Topic: Nitpick question on samplerate. ADI-2 DAC fs
The specs for ADI-2 DAC fs says it can take any external clock between 28 - 200 khz. When I feed it with a 32khz/16bit coaxial, SPDIF signal, State overview says: Sync(steady) -- 32 -- cons -- 16, everything OK alright. But in lower right corner the SR indication shows 32 displayed in red, indicating somethings wrong.
Is this an interface bug or is there actually something wrong with the signal/sync/lock. In my experience the SR indicator shows red when the samplerate is of by a ten or so ex. 44.2 or 44.0
It seems kinda wrong 32 khz being a standard of sample rate like 44.1, 48 or 96. And its whitin the specs of the device.
Re: Nitpick question on samplerate. ADI-2 DAC fs
32 kHz are not supported on the driver side, but you can use 32 kHz as digital input and listen to it. So everything is as expected.
Thnx for clarification MC smile
