Topic: Sample rate jumps automatically to 768 kHz using the analog input
Hi guys,
I've got an ADI-2 Pro FS R which I like very much but there is one use case which I do not understand.
Here is the scenario:
I do have my phono pre connected to the analog input of the ADI-2 Pro and I've got an Auralic Aries G1 connected to the USB port and a CD player to the coax input.
So if I just want to listen to vinyl I switch the basic mode of the ADI-2 to AD/DA and select the source "Analog" for the Output 1/2 which is conneted to my amp. The Auralic and the CD player are switched off.
If I do so the sample rate jumps up to 768 kHz with the unwanted effect of turning off my EQ for room correction.
Actually I couldn't find any way to switch the sample rate to 192 kHz or below to activate again the EQ.
The only workaround is to turn on my Auralic or my CD-Player which obviously will set the internal sample rate to e. g. 44.1 kHz.
Is the ADI-2 Pro not smart enough to detect that there is no valid input signal of my Auralic at the USB input while being switched off and setting the sample rate automatically to 192 kHz or lower to preserve the full functionality of the DSP?
Looking forward to your feedback
