beat8000 wrote:As an alternative I would consider a near field monitor with digital input and DSP (e.g. Neumann KH 120 D) and connect it purely digitally to the ADI-2 .
Such a concept has disadvantages.
It's not unusual to use active monitors for more than 10 or even 15 years.
1. This means you would be stuck to the converter quality of the KH 120 D for a very long time plus the time where it has been on the market already (usually d/a converters are not changed in one product).
2. You have to pay a much higher price for these monitors without getting more quality, because it's still the same monitor only with more electronic and because it's only rarely sold in much lower quantities.
You have more flexibility to perform the D/A conversion in a unit that is dedicated for this purpose and where the innovation cycle is much shorter.
Also you can compare products much better by using dedicated converters/active monitors and keep then the best combination.
Furthermore you have with the RME converters ADI-2 DAC/Pro the following advantages:
a) ability to select the D/A filter for other criterias then only the most linear frequency courve (see posting from KaiS why he prefers the Slow filter).
b) the bittest to validate lossless data transfers end to end in the digital domain
c) RME's legendary steadyclock technology to suppress noise and jitter just before D/A conversion with the DAC's ultra precise internal fs clock.
d) RME's design to use four different reference levels in combination with auto reflevel to keep highest SNR and dynamic over a much wider volume range and this in combination with dynamic loudness, B/T and PEQ.
My advice to o.p.
You have already the ADI-2 Pro FS R BE, it's a gem....
Now concentrate to get the best active monitors or combination of power amp and passive monitors and then make use of all the high valuable features of ADI-2 DAC/Pro which are uniq in the market in this combination and quality.
My two ADI-2 Pro FS R BE play extremely well in front of
- Geithain RL906 / Audeze LCD-3
- Accuphase E-600 and B&W 803D3
I can only recommend to make use of all the outstanding features of the ADI-2 DAC/Pro including the D/A conversion part.
