Topic: IPAD compatible with Babyface
Hi!
I have iPad 10.2 (8. gen) and Babyface Blue (discontinued model).
Will IPad work with Babyface?
Thanks!
2 (edited by waedi 2021-12-13 05:42:22)
Re: IPAD compatible with Babyface
As your iPad has a lightning connector you need that adapter :
https://www.digitec.ch/de/s1/product/ap … ier=406802
Set your Babyface into Class compliant mode (CC-mode) by holding the buttons SELECT and RECAL during powering.
By default the XLR outputs (ouputs 1/2) deliver the sound from the iPad, for using the Babyface headphone output
select output 3/4.
For recording two condenser mics (wich use phantom power) an external power supply is recommended (needed).
This power supply : https://www.thomannmusic.ch/rme_ntcardbus_x.htm
