n00BRX wrote:I have custom made a XLR to RCA with PIN 2 disconnected for DAC XLR output to a ncore RCA input.
Maybe just a typo, but ...
It‘s pin 3 (XLR middle one) that should be disconnected.
Pin 3 signal is phase reversed, which under some circumstances can sound different.
You can use an RCA-RCA cable for the same result BTW.
n00BRX wrote:... am I losing the +6dbu even I am using the XLR output?
With unbalanced destination this is the only way to do it, yes.
“Losing” sounds so negative, as if a higher level was better in any way.
Usually in a home environment it’s not, just the opposite.
RME ADI-2 DAC can go quite high, above what is needed.
Often passive attenuators are mandatory to fit the level to the power amp connected.
Read here about details, please:
https://forum.rme-audio.de/viewtopic.ph … 21#p161721
Insn’t the Hypex NCORE’s input balanced anyway, why not use a XLR-XLR for fully balanced interconnect?
Else you might need this:
(Watch out for the direction in the diagrams below, ADI-2 would be to the LEFT with your current connection!)
