Topic: Connecting RME ADI-2 AD / DA converter with optical portless Mac Mini
Hi Forum,
I am currently contemplating the purchase of a RME ADI-2 AD / DA converter, which I would primarily use to digitise analogue audio signals. The digitised audio signal is then to be fed into an Apple Mac Mini M1 (2020) for further processing. These two pieces of hardware, however, are not a natural match, as the RME ADI-2 AD / DA converter doesn’t have an USB port, and the Mac Mini is lacking an optical S/PDIF port. My question here is what options there are to connect this converter and computer? The market doesn’t seem to offer a lot of options for converting signals from optical S/PDIF to USB, and what I come across is of unknown quality and offered by manufacturers with (at least to me) unknown credentials. I am hence curious to know whether any of you is using the RME ADI-2 AD / DA converter in combination with a computer that lacks an optical port and what solution you employ to feed the digitised audio stream generated by the converter into your computer? I am aware of the existence of the RME Digiface USB, but since this seems to be a bit of overkill, I’d be grateful for any other suggestions you may have.
Cheers,
Simon
