1 (edited by Johannes AU 2021-12-30 13:10:26)
Topic: I got a TEAC AG-D8000 old Amp and need some help
I got a TEAC AG-D8000 old Amp and need some help.
The block diagram https://www.manualslib.com/manual/17416 … D8000.html
I will connect the Adi-2 Dac Fs to AUX in and some other output to CD in.
Anything I have to observe (such as ref level, 8dB?) if I use it as a 2.1 system?
[The user manual doesn't state if the Line in voltage is 2V or not, I assume it is]
Pacifist, dumb, not stupid
2 (edited by KaiS 2021-12-30 15:04:23)
Re: I got a TEAC AG-D8000 old Amp and need some help
Johannes AU wrote:
...The user manual doesn't state if the Line in voltage is 2V or not, I assume it is
The exact voltage isn‘t critical.
Follow this advice, nothing further to observe:
https://forum.rme-audio.de/viewtopic.ph … 21#p161721
3 (edited by Johannes AU 2021-12-30 16:20:42)
Thank you KaiS, the old TEAC works great, and its 100W spec at 6 ohms fits my speakers, old electronics still work like a charm~ smile
