1 (edited by superdrive 2022-01-03 15:11:07)
Topic: Dig Out custom level volume.
Would it be technically possible to add custom volume setting for Dig Out when set to "Default" or can there be a third option that allows volume control?
For example, I would like to have about -3dB from ADI-2 Pro's AES-EBU output, that is independent from Main Out Volume.
Currently, I can only set it to Default (full level signal as it is) or Main Out (not independent from Main Volume)
Thank you very much for a great device.
Re: Dig Out custom level volume.
You can have that kind of functionality when using phones3/4 as main analog output, a simple workaround.
RME have mentioned several times that pretty much all DSP and uC capabilities are used up by now, so it's unlikely we'll see that kind of extended features.
