Topic: Fireface UC not detected after reboot (Big Sur 11.6.2, RME 327 driver)
Hi.
My Fireface UC is not longer detected anymore since I upgraded my Mac (Big Sur 11.6.2).
I installed latest RME driver (327), and it worked fine, but since I rebooted the computer, the audio interface is not longer detected.
Thanks for your help.
2 (edited by dsl 2022-01-04 18:58:19)
Re: Fireface UC not detected after reboot (Big Sur 11.6.2, RME 327 driver)
Unfortunately, I don't have a solution, but I have the same issue on different devices (also on macOS 11.6.2, installed the most recent driver).
I have a Babyface Pro FS, and a Digiface USB. Both are not recognized as audio devices in macOS anymore.
I just figured out a strange thing:
When opening the firmware update tool "RME USB Series Flash Tool" while both devices are connected, they both show up in the dropdown menu. First I thought it might be cached or so, so I disconnected one device --> It showed just the connected device in the dropdown list; Disconnected both --> "RME USB Series Flash Tool" closed immediately after start.
So it seems like the USB connection is working. The devices just do not show up as audio devices in macOS.
*Edit: Using Class Compliant mode on iPad also works fine (using Babyface Pro FS, not tested on Digiface USB)
Ok, the solution is there...
https://forum.rme-audio.de/viewtopic.php?id=33277
I'm sorry, but it doesn't work.
At least on my computer.
I accurately followed these instructions and still can't open the TotalMix window...
Help !
Did any of you rolled back to an earlier version of macos? I downloaded 11.6 and I am installing it tomorrow. I will also try figuring out what drivers and firmware was functional at the time of this version and see if I can get my mac mini operational again.
So, here is what I tried, and didn't work (the name of my default drive is MacDavid) :
- boot into recovery mode
- open Terminal
- run the kernel extension panic medic boot command by typing: kmutil trigger-panic-medic --volume-root/Volumes/MacDavid
Then I had this message : Missing expected argument '--volume-root <volume-root>'
Nothing else happened.
And I hadn't to allow anything when I opened Security&Privacy after rebooting.
The Fireface still doesn't appear as un usable device. Even after re-installing the latest driver.
So, I'm totally blocked.
You missed a space in the command, after the word "root"
Oh yeah !
Thanks !
Perfectly worked this time. Be sure to (re)install driver BEFORE rebooting after authorising.
