Topic: BabyFace Pro, Total Mix won't open
I have a Macbook Pro M1, I have successfully used Totalmix after installation for a few months now. Yesterday my Babyface Pro fell on the floor, the round plastic knob came off, I put it back on, my computer didn't recognise the sound interface anymore.
I rebooted Babyface Pro by pressing Select and Dim together, now I could see the Babyface Pro in the sound menu appearing, but I couldn't open Total Mix.
I reinstalled it several times, to no avail, I even rebooted the computer allowing kernel extensions, checked for the allow security button, but still I can't open Total Mix.
I'm not sure if my interface is broken, if I did something wrong to press Select and Dim at the same time, or if I made a mistake in the installation.
Thanks for your thoughts!
Re: BabyFace Pro, Total Mix won't open
You changed to CC mode. Change back to PC mode...
Hi Matthias! Thank you so much! That worked!
