Topic: Help setting Ref Level
Greetings! I'm going to admit that the RME-ADI2 DAC has opened a whole new world of terminology and
subject matter that I'm ignorant of. Which is great! Because I'm learning. But I could use some help
understanding what the best settings for Ref Level would be in my particular setup.
Node (v3) -> Coax -> RME-ADI2 DAC -> RCA -> Musical Fidelity M1PWR -> Paradigm 40b + RCA
from loop outs to JBL D110
I can't seem to find the input sensitivity for the power amp... MF M1PWR. Is this what we would use
to determine the best ref level for what is essentially an IcePower amp?
When I select auto ref, it ends up at -5, and most of my listening occurs in the -50 to -40 dBr range...
and when I turn it off, and run it +7 most of my listening occurs in the -40 to -30 dB range.
I have a small room, listening distance is usually only 7', and the speakers are sensitive (Room / Anechoic 92 dB / 89 dB).
In 31.12 Operation in the Hi-Fi Environment the manual states:
"With Hi-Fi, the setting +7 dBu (equals +4.78 dBV or 1.73 V RMS) is recommended. This setting causes an ADI2-DAC to ouput level similar to that of many CD-players."
Is this assuming that when "Operating in a Hi-Fi Environment" and outputting at a level similar to CD Players, it would NOT be acting as a pre-amp... that this 1.73 V signal would be used as an INPUT to a pre-amp?
Therefore, since I AM using the ADI2 as a pre-amp... and I AM using its volume control... I'm better off allowing it to auto-adjust?
19.3 Line out XLR (seems to be the ONLY explanation of Auto-Ref I can find in the manual)
"The analog outputs also feature a mechanism to set the ref level automatically. Auto Ref Level maximizes the S/N ratio when using the volume knob."
OK... so I AM using the volume knob. Therefore again, I should use Auto-Ref .... correct?
I have read through the "Where to adjust volume" and "Level mismatch solutions" threads and just come away more confused than ever. I'm not sure what I'm experiencing here is a level mismatch requiring attenuation or what.
Should I just keep it on Auto-Ref and not care that I'm so deep into the negative numbers?
What REF level will make this little power amp most happy? Thank you for your assistance!
