Topic: Mic Gain between 0 & +10 dB not possible
for some reason the gain for Mic input 1 on my RME Fireface UC in total mix won't let me set values between 0 and 10. Above 10 every value can be set but below 10, 0 seems to be the only possible setting. Strangely it behaved normal just a few weeks ago if I remember correctly.
Does someone maybe have the same problem and or has an idea how to repair that problem?
Cheers
Re: Mic Gain between 0 & +10 dB not possible
It has always been like that. Your memory fools you. And a look into the manual would have revealed that too.
Ok thanks. Good and bad news at the same time i suppose haha
