1 (edited by m.holmes 2022-01-07 16:44:24)
Topic: Digital DC protection triggering?
Hello forum,
I found a song that triggers the DC protection on ADI-2 DAC when played via usb.
for the curious: it' track 10 from
https://www.discogs.com/release/1001335 … hen-Hippel
which is freely available from here:
https://www.germanremixgroup.de/content … wnload=160
Now, in my case the "fix" was pretty easy: I just recomputed ReplayGain for the song, and it now plays through.
(is this expected?).
However stopping playback entirely seems quite a drastic choice: maybe we could have an option in firmware to just -say- display a huge warning on the screen and keep on playing temporarily in a safe way? e.g. auto-lower the volume or filter some frequencies out?
all the best
2 (edited by Curt962 2022-01-07 17:11:20)
Re: Digital DC protection triggering?
Stopping Playback isn't so drastic when expensive gear downstream is at risk.
You have the option of turning Digital DCP off, but that is neither advised, nor wise.  *an exception might be in a Lab Test environment where Test Signals may contain DC.
Refer to your User Manual (rev 2.9, Pgs 68/69) for a more thorough explanation of the DCP system.
An easy, and unobtrusive method of dealing with offending sources is to incorporate a simple High Pass Filter at 20hz in your PEQ as described by MC (RME) quite recently.
Curt
Cables:  Red, and White Ones.
Speakers:  Yes
The song needs remastering process at lower volume.
It is clipping constantly at plus 0.7 dB true peak, measured with Youlean Loudness meter.
you can lower the gain of your play software ?
You definitely don't want to damage your hardware, but you might think of different countermeasures -say- "dim" the volume down to a safe level and keep on playing.
Right, but I don't want to do that permanently. As the dac knows exactly when to engage the protection, I'd find it quite natural to have an option specifying what the reaction should be (e.g. instead of dc protection on/off, I'd like to have: stop playback / dim volume / high pass filter / off)
yes, in fact just applying replaygain is an effective fix.
6
The most effective fix is planned for the next firmware update. Until then you can turn off the Digital DC protection and only get the message, but not the mute.
7 (edited by KSTR 2022-01-07 21:17:26)
https://abload.de/img/dc-offset6wk40.gif
This what's left when the track is steeply lowpass-filtered at 1Hz! (8th order)
No wonder it triggers the protection as the DC-levels are significant (-27dBFS == 4% of FullScale) plus useless infrasonic content.
Extemely bad recording and mastering at work.
I'm curious... a switchable infrasonic highpass-filter?
Thanks for the analysis.
Let me state explicitly: I'm not saying that this song is a "false positive" of some sort.
My concern is a bit different: after installing the firmware update, it took less than 24 hours to trigger the DC protection warning.
I admit I didn't compute the probability, but from these numbers the issue doesn't seem "uncommon" and -if this is true- I strongly feel that a more "forgiving" workaround is required.
Otherwise users will perceive the "protection" as an annoyance, and just turn it off (which is bad).
No need to say, I'm curious too...
Usually I don’t like speculations but this time I can’t hesitate to give a bet:
As the new DC protection measures the DC content of the audio signal it might be a DC-servo function that nulls DC output.
12 (edited by ning 2022-01-08 07:33:34)
Yes that’s pretty simple and straightforward to implement.
Here's an example: https://www.xilinx.com/support/document … /wp279.pdf
RME already did the heavy lifting part in the last firmware update. the remaining is simple
13 (edited by Johannes AU 2022-01-08 10:37:50)
Good Morning from Hongkong.
Could be I am the first one encountered the Digital DC protection during the pre-test session, within 30-40 minutes of internet radio.
We do not know the recording is bad before, and play it loud, possibly damaged something and never know the cause and live with it, now this new function let us know and can protect downstream equipment, not bad at all. I think that is a good feature, though a bit trouble for some applications.
If let it off, the warning screen still shows, audio goes on, feel even worse after saw the warning screen, who can live with knowing something bad happens and let it stay and keep on listening?
A more forgiving protection or turning it off, it reminds me the name of a tennis star, or put a copper bar instead of a fuse.
Let's wait for the next firmware, I am confident MC and the RME team will find the best way to make it works in a better way.
Use the first aid MC recommended and kindly be patient for the next update. smile
Pacifist, dumb, not stupid
that was my point too.
I also came across a song with the same problem. If you have it downloaded locally, you can use Effect>Normalise in Audacity. First apply the DC offset. If the song keeps triggering the DC warning, keep lowering the gain until the warning disappears. Export the new file and good job, you are better at mastering than the sound engineers themselves.
Here's a track which triggers it:
https://dimaquiet.bandcamp.com/track/altitude-realtime
(Turns out, quite a number of "chiptune", ie old computer generated music using square, triangle and sawtooth waves in various distorted ways, triggers the DC protection so with that type of music it's apparently not that uncommon.)
17 (edited by KaiS 2024-11-26 23:28:37)
Just a reminder:
ADI-2 offers a filter that removes the DC problem before it damages anything:
I/O / xx Output xx/ Settings / Dig, DC Protection: Filter
This way even heavily DC polluted tracks can be played.
The filter is way below the audible range, doesn’t negatively affect the sound.
