Hello -
Yes, I was counting on using the built in networking feature of the RME Digiface Dante to run Dante Control for the network as well as control the MIDAS M32 mixer remotely. It works fine in this manner except for the issue with DPC latency.
I have worked extensively with the Windows Performance Recorder and Windows Performance Analyzer in order to determine exactly which drivers are causing the peaking latency issue.
To date, I have been able to run "realtime" without issue only by disabling the RME built in network adapter. I then discovered that even though I disabled processor throttling and disabling processor idling, if the laptop gets too hot I will have regular dropouts due to peaking of DPC latency in the USB driver. This ASUS N501VW laptop uses the Intel 100/C230 chipset for USB 3.0. As the laptop also supports Thunderbolt 3 and associated USB 3.1 independently from the USB 3.0 controller, I had hoped to improve the situation. There was a slight improvement, but I still can't run the RME network adapter, and I still run into heat derived throttling.
This is with the latest 0.9.566.0 network driver, FW 45 and the 0.9.747.0 audio driver, very latest USB drivers (even tried some modified drivers), careful to disable power management on the drivers, etc. While I can run Wifi adapter and control the mixer without affecting the realtime performance, I still can't keep the system cool enough to perform reliably.
I've had better luck with my workstation using a PCIeR Dante adapter from Focusrite, so I may well build a rack mount PC in order to overcome these obstacles for the mobile rig.
PS - I did try a separate ethernet networking adapter, with same issues as RME built in adapter. I also have an Ubuntu Studio installation but could not get ALSA to recognize the Digiface Dante.
Thanks again for your kind assistance.
Cheers
Robin
