Topic: UFX+ crackle
Dear all!
I am running a UFX+ with a ADI-8 MK2 on an iMac Pro (11.6.2) @96kHz  with Reaper. Recently, I hear a crackling sound over the speakers and eventually I get an overload and Reaper will Mute the channel. If I check DIGI-CHECK, channels 01-22 show signal at -90dB when nothing is playing. The other channels show not signal down to -140dB.
I reinstalled the RME drivers but the problem is coming back after some time. Really strange - dying capacitor? Any suggestion?
Thanks in advance,
D
Re: UFX+ crackle
And you did not have the idea that low level signal is the base noise of the analog inputs?
You run the UFX+ with USB 3? Check the Settings dlalog for USB errors when the crackling reappears.
Re: UFX+ crackle
The Fireface USB setting app is reporting CRC errors.
I am running USB3, the cable is plugged into the USB port of the iMac Pro.
The analog inputs are 'empty' that is have no cables.
What can I do next? I reinstalled the driver & checked the cables.
Thanks in advance.
4 (edited by Soundwunder 2022-02-01 21:57:19)
Re: UFX+ crackle
I could record a spectrum when crackle and pops start while running noise at low level. It shows some very narrow equally spaced high-freq. peaks, a bit like feedback. Unfortunately I am not sure how to upload an image. Perhaps that helps.Cheers
Re: UFX+ crackle
Finally, I wiped the HD & made a reinstall. So far, it is quiet.
However, I get lots of CRC errors. What does that mean and how can I improve that?
Thanks in advance!
