Topic: TotalMix FX not appearing and no sound from Babyface
Hi.
I'm using:
Babyface with driver 1.219 and hardware revision 225.
Windows 10 v 21H2
Lenovo Yoga laptop
Sibelius notation program
When I click on the FireFace USB icon, only the USB config window opens; TotalMix FX window does not open.
No sound is produced (oven through headphones directly connected to the Babyface) even though the notation program accepts MIDI keyboard input.
Please help.
Thank you.
John
Re: TotalMix FX not appearing and no sound from Babyface
There is no reason TM FX should open when you click the USB Settings dialog icon. Click on the TM FX icon instead (which might be hidden behind the chevron).
Thanks for the prompt reply. The only 'hidden' icon (behind the chevron) is the one I clicked (the one with the flames...) which is labelled 'Fireface USB Settings' when I hover over it and it only opens the USB settings. There are 11 of  these 'hidden' icons altogether, and all the other ones go to VPN, Skype and so on. Nothing else relates to RME / TotalMix.
Is there some other way I can get to TotalMix?
Thank you.
I think this article might help: https://www.sibelius.com/helpcenter/art … id=2356090
ADI2, Digiface, ARC
Windows may have arbitrarily blocked the TotalMixFX.exe from running at startup.
Hold CTRL+ALT+DEL, launch Task Manager, click "More Details" at the bottom. Go to the Startup tab. Find the totalmixfx.exe file in the list, and check that it's showing "Enabled". If it says "Disabled", right click and select Enable. When you reboot your PC the app icon will be in the tray again.
Thank you, Jeff! That was the answer and it all works perfectly.
Thank you, fieldstu, for your suggestion. The link went to 'Not found', but fortunately, once TotalMix was functional, Sibelius worked seamlessly with Babyface.
John.
