1 (edited by AChernavsky 2022-01-31 09:52:51)
Topic: No sound on 7+8 outputs with WDM. RME UCX II, Windows 10 20h2
Hello!
Today I've got a very strange problem.
All is working ok but there is no sound when I route windows sounds into my default phones out (7+8)
All other outputs is working ok with windows
ASIO is working ok with all outs including 7+8
I tried to Total reset in TotalMix, turn on\off RME, turn off PC - no luck
Perhaps windows updates is the reason? but they don't affect sound according to the description..
Any suggestion how to fix this?
latest drivers, latest firmware
kind regards, Alexander
2 (edited by AChernavsky 2022-01-31 10:53:29)
Re: No sound on 7+8 outputs with WDM. RME UCX II, Windows 10 20h2
Ok.
I fixed the problem.
The issue was - Equalizer APO (EQ correction profile on 7+8 out)
Somehow insert plugin was brokened neutral
if someone using ProQ with the Equalizer APO, this fixed an issue:
https://sourceforge.net/p/equalizerapo/ … 7c0e33944/
Insert clean ProQ vst before actual working ProQ
regards Alexander
