Regarding MADI
MADI: you connect one or more devices in a serial fashion, in your case with only one device (preamp):
UFX+ MADI OUT -------> MADI IN - Antelope
UFX+ MADI IN <------ MADI OUT - Antelope
To connect each of the up to 8 - or even more - devices on a MADI bus, patchcables are available from 0.5 up to approx 50m.
Longer ranges - up to 2km between each of the devices (!) - are possible, just in case the equipment is distributed between different rooms / floors. There you might have optical inhouse cabling where it is important not to mix the optical cable standards, either OM3 or OM4, in such a serial ring of devices on one MADI bus.
But if everything is in a rack you only need a short cable of approx 1 or 2m to be flexible, e.g.:
https://www.kabelscheune.de/LWL-Kabel-L … 4-2-m.html
You can also use 0.5m if the devices are very close to each other, but take care not to bend optical cables too much.
Word clock - possible, but not required
To use word clock is not a strong requirement. You can also use the clock signal which is part of every digital connection (ADAT, SPDIF, AES, MADI). According to RME there is not difference in quality and RME devices with Steadyclock (FS) technology are anyway capable to remove the clock jitter from WC and any digital input, to refresh the clock and perform AD and DA conversion by using it's own local clock. So every RME device is also a perfect clock slave by RME's Steadylock technology.
RME Steadyclock
More information about Steadyclock here, both available in English and German:
- Product Page from webserver: https://www.rme-audio.de/steadyclock-fs.html
- Interesting Youtube video from Matthias Carstens: https://www.youtube.com/watch?v=Ti0aHW-zYcs
Option 1) UFX+ as clock master
You could make the UFX+ to clock master
- Octopre Clarett could learn clock through it's ADAT input
- Antelope could learn clock through it's MADI input
The benefits of using the recording interface (UFX+) as clock master: you only need to set the clock in the DAW project, this sets the clock at the UFX+ by the application through the ASIO driver and all clock slave learn it automatically from it's digital inputs.
But note: it could be the case that only sample rate changes in single speed between 44.1/48 kHz are recognized properly by all clock slaves, because with ADAT and MADI higher clock rates (as double and quad speed) are reached by multiplexing/"bundling" two/four channels, there it is not possible to distinguish between single/double/quad speed. In such cases you need to readjust at the device. Then it's good if all devices can also be operated remotely depending on where they are located. Premaps most likely close to or in the recording room.
Option 2) Antelope as clock master
If you prefer to use the Antelope as clock master, this is also possible.
Also here WC cabling is not required, UFX+ can act as clock slave, Steadyclock - as mentioned above - will remove any potential clock jitter from MADI, refresh and further distribute the clock to the Clarett.
Depending on the location of the Preamp in your or in another room it could be a big disadvantage to use Antelope as clock master, as it can only be operated through USB which has length restrictions.
A review of the Antelope at Bonedo tells, that they regard it as disadvantage that you need the control software and thus an USB connection between Antelope to the PC to be able to operate the preamp.
At the front of the preamp you only seem to have controls for mic gain but not more.
Not even for the volume of phones output and - if I see it correctly - also not the possibility to change the clock.
This gives away all the possibilities of MADI to place the devices directly in the recording room, because the way to the monitoring room will be much longer than 5m (USB2 max cable length) in many cases.
https://www.bonedo.de/artikel/einzelans … est/2.html
Some recommendations / proposals for the future
Allow me a few comments, maybe this is beneficial to you for future planning and as your recording solution is based on the UFX+ with TotalMix FX.
I think it would be more beneficial to use a RME preamp like the 12Mic in combination with a RME recording interface with TotalMix FX because of the unique RME features that you get with such a combination.
Advantages of the 12Mic
- high port density in only 1 RU (rack unit)
- transparent high quality preamps that match the quality of those from UFX+ with +75dB Gain
- high quality FS (femto second) clock / Steadyclock FS
- Autoset (automatic gain reduction preventing overloads caused by too high gain setting)
- fully operational at the display
- easy and intuitive operation at the device using combination of button for port selection and 4 buttons +1 Encoder
- high quality phones output, where the volume can be set at the device
- supports MADI and AVB
- different remote control possibilities
- Browser based through network
- by using the new MIDI remote software
- Auxdevice Support (hopefully soon, promised by RME, delayed by corona/chip crisis)
- Standby by pressing big encoder in the front, full power-off by switch at the back
- integrated PSU and PSU redundancy
- Prices per port: 12Mic: €2449, €208 per port
// Antelope (price from 08/2015) €2195, €274 per port
- RME: long product lifecycle, long term driver support
// Antelope: product not being sold after ~5-6y, last control software from 2016
- Antelope: control software needed and thus needs to be supportby the operating software and work with USB
Auxdevice Support
Auxdevice to intergrate the 12Mic into UFX+ like the Octamic XTC.
This is really a very useful and impressive feature making operation very quick and comfortably.
Allows you to control the 12Mic with TotalMix FX by using RME's "MIDI over MADI" feature.
You can not only remote control the most important Preamp functions, but also save and recall these settings through TotalMix FX snapshots and workspaces.
But you can not only control the 12Mic locally through display / knobs or broswer based through network.
RME roffered for the time being MIDI remote software, which is very useful for live installation where you have no LAN/WLAN.
Then you can control the 12Mic e.g. "on stage" remotely using MIDI over MADI through the MADI cable, see here:
https://forum.rme-audio.de/viewtopic.ph … 02#p183202
12Mic - flexibility in placement
With one or two 12Mic you can position a preamp for example in any recording room "close to the action", so you would also have shorter cable runs for XLR cables in the rooms, which reduces costs and also keeps the cable clutter in check.
12Mic - final thoughts
By all these features you do not only have a preamp of very high value & quality, but also a lot of options regarding operational comfort which I regard as important as technical quality so that daily work/operation is vey smooth and comfortably.
Furthermore you are future prove as the 12Mic supports besides MADI also AVB. You can use the 12Mic even in AVB networks to integrate "old" MADI components to it, see my review below.
12Mic - Reviewed
If you want some further information, you can read this review:
https://www.tonstudio-forum.de/blog/ind … XTC-DE-EN/
Direct link to PDF:
EN: https://www.tonstudio-forum.de/index.ph … n-1-0-pdf/
DE: https://www.tonstudio-forum.de/index.ph … e-1-0-pdf/
BR Ramses
UFX+, 12Mic, XTC, ADI-2 Pro FS R BE, RayDAT, X10SRi-F, E5-1650v4, Win10Pro21H2, Cub12Pro
