Topic: Normal or Hi Power for Audeze LCD-5
I did some initial testing this weekend with my ADI-2 Pro FS R BE and was able to use the normal power mode to power my LCD-5 to comfortable listening levels while working, but if I recall, I was in the -15 to -8 range on the headphone output. Not super close to 0dB, but getting there...then I noticed that the level control goes higher than 0dB.
I experimented a little with hi power vs. normal and decided to go with normal mode but I won't be able to test again for a few more days. Generally speaking, they seemed to require a little more gain than the LCD-X or LCD-4z did to reach the same listening levels, but I'm not quite sure that it means going over to hi power mode.
I know that using my ears and trial and error is best but from a purely technical standpoint, working with material that is being mastered (so anywhere from -14 LUFS to -7 LUFS on average), would one suggest using the normal mode, or hi power mode?
Here are the headphone specifications:
Transducer size - 90 mm
Maximum SPL - >130dB
Frequency response - 5Hz - 50kHz
THD - <0.1% @ 100 dB SPL
Sensitivity - 90 dB/1mW (at Drum Reference Point)
Impedance - 14 ohms
Max power handling - 5W RMS
Min recommended power - > 100mW
Recommended power level - >500mW
