Topic: Babyface and dynamics
Hello, there is a lot of discussions about the lack of compressor (or other dynamics, like gate) on Babyface Pro FS, and the common answer is: „If RME would add compressor processor to Babyface, it would be necessary to add a second chip, because current dsp chip doesn't have that much power. And it will cause, that BF will be less portable and more expensive, and RME don’t want to do that.”
I fully understand, why RME don’t want to make BF less portable and more expensive, but I have 2 questions on two different scenarios:
1) If I understood correct, Babyface reverb and delay – unlike in the higher RME models – are computer CPU based for the same reason: BF DSP chip isn’t so powerfull to handle EQ and reverb, and delay. So why not add CPU based compressor to Totalmix and make it avaible with Babyface? It won’t load DSP procesor and it will be better than nothing.
2) I don’t know if it is technically possible for current Babyface DSP chip to process compressor algorithms at all, but if yes, if this is only DSP load problem, why not to add compressor and limit it’s capabilities to operate on each channel toghether with EQ. For example sometimes there is no need to use EQ on every In and Out, but just on main outs. And maybe with such a load on the processor there will be enough power to add compressor only on one channel.
