Topic: How to Save an Eq preset
Hi there, I'm hoping someone can help me. I have the RMEADI-2 DAC fs. I cant for the life of me save an EQ on this bloody thing.
I go to the EQ settings, create my desired eq. Go to the next part, name it ect. And hold the save button for 2 seconds, it says its done. When I go back to it, the only thing that has saved is the name I have chosen, the eq is back to being flat.
I have read the manual, and feel like it should be simple. I'm 34 and relatively tech savvy.
Can anyone please help me? I would be forever grateful.
2 (edited by KaiS 2022-02-13 15:30:12)
Re: How to Save an Eq preset
I do this all the time, now trying to imagine what might go wrong, maybe:
In the “Save to (push 1s) ##”-field, did you see and select the number “##”, e.g. “1”, “2”, etc. of the preset slot to save and recall your setting?
Save is Encoder 2, but this is probably clear?!
3 (edited by Jperkins 2022-02-13 15:40:36)
FWIW, I found it hard to discern if you're in the "Save" section or "Load" section when saving presets if you're not looking super closely.
Sorry to resurrect this old thread, but I have the same difficulty and hopefully this has been resolved by now.
Specifically, how can I load a certain EQ preset and then, after changing it, save it into another slot?
I need to modify an existing EQ and save the modified one into another slot so I can retrieve depending on what I'm doing.
So far: I go into the 1st EQ screen (press EQ button), press Enc 2until the preset select appears and select a preset, which is shown in the bode plot, active, colors on. Let's say this is preset 4.
Now I make a change, that is reflected in the bode plot, colors active. I want to save this changed EQ in say slot 10.
Press EQ button 2nd time, and I get into the EQ Enable/Presets screen. I navigate to Preset Select, select slot 10, step through the name fields, till I get to the Save (1s) field, press Enc 2 until I get Done. So far so good.
Now I go back to the initial EQ screen, press Enc 2 until the preset selection screen appears, select preset 10 and the bode plot comes up emplty (flat, colors active). Tried several times, no luck.
What am I missing?
Jan
5 (edited by KaiS 2023-03-22 15:21:38)
jan.didden wrote:
...how can I load a certain EQ preset and then, after changing it, save it into another slot?
At this point select “Manual” - the source preset.
“Manual” is selected as default when you changed an existing EQ, so typically nothing to select at this step.
At this step turn Encoder 2 to select the destination, e.g. 10.
press Enc 2 until I get Done...
6
The point is not to select anything - that is the wrong approach as you LOAD a preset that moment. Skip this step.
Well, it seems I DID miss something ...
At the end of the process, when you are about to press Enc 2 to 'Save to (push 1s) x', at that point, you can turn the encoder to change the x to the slot where you want to save the EQ. And that does just what I want.
I never picked that up, but in blissfull hindsight it makes total sense.
Jan
Yes, edited my posting above to make that totally clear.
Thanks Matthias, yes that makes sense, especially now that I discovered you can select the slot to save to just before the 1s push.
All falls into place now.
The ADI-2 Pro manual starts to become quite colorfull with all the text I highlighted ;-)
Jan
