entertainme wrote:Does balanced output change the voltage output of the ADI 2 Pro or does it only increase power?
It doubles the voltage, in conjunction with an unchanged electrical impedance, this results in twice the current. Double voltage times double current means quadruple power. (exception: very low impedance, see chapter 34.18 Extreme Power Charts in the user manual)
entertainme wrote:I find the pentacton connections less reliable than XLR or 6.35mm.
Agreed. I would also prefer 4 pin XLR. The 2 times 6.3 mm TSR solution is very unusual, DIY announced and, as read above, someone can very easily plug in something wrong.
But now, not only Sony, also Sennheiser, Astell & Kern, FIIO, ... uses Petaconn. T+A offers both, but with 5000 bucks for a headphone its easy to to so. Compared to the slender* 2.5 mm TRRS Plug the Pentaconn is very reliable. (*I 'm not sure whether English "slender" has the right negative facet, the German word "spiddelig" has).
KaiS was faster, i was thinking too much about slender. But to me the second chart seems to show the comparison between high and low power, not between single ended and balanced. The first shows the 6dB between single ended and balanced.
Ralf
(ADI-2 Pro FS with ThinkPad Yoga L13, Dynaudio Focus 600 XD or Focal Clear — and a lot of Jazz)
