Topic: Planar headphones with the ADI-2-Dac-DS
I am curios about using planar headphones with this Dac. I have this great Dac with the AKM 4493 Dac chip. I am using the Sennheisr HD-650 300 Ohm Cans with the high power setting and find it beats out my Tube headphone amp. My speakers are hybrid with a ribbon on top yet the speaker have a sensitivity of 94 db.
I do not what what the output measures yet I believe the high power adds 15DB. I see the Video with MC using planar headphones.
Are there any Planar headphones reasonably priced that will play well using the RME and have a high enough sensitivity? her in the USA you have MR speakers, Audeze, HiFiman, etc. I se some Chinese  brands that are reasonably priced.
Any suggestions? I look forward yo your feedback.
Liz
2 (edited by KaiS 2022-02-22 15:37:13)
Re: Planar headphones with the ADI-2-Dac-DS
Hi- or Lo-Power only switches the DAC’s out gain by 15 dB.
Think of it as a coarse, two step, analog volume control.
The analog headphones power amp itself stays at unchanged full power.
Therefore both modes preserve the same, high, analog amp quality.
For this reason I suggest to use “Auto Reference Level”, it automatically switches the gain according to the needed volume, optimizing Signal to Noise Ratio SNR and usually improves on it by the mentioned 15 dB, compared to fixed Hi-Power.
II see the Video with MC using planar headphones.
ADI-2 DAC can drive every headphones, even what they call “hard to drive“, with ease!
Sensitivity is not critical by any means.
“Reasonably priced” - the Hifiman HE-4XX is hard to beat.
https://drop.com/buy/drop-hifiman-he4xx … headphones
Even more so if you live in US.
It’s sound signature / frequency response is close to the Sennheiser HD 650, adding what you typically expect from planar magnetic headphones - deep bass down to the subs and clean, transparent midrange and treble.
I have the HE-4XX ($160) and the HE-1000 ($3500), and their sound quality is by no means as far apart as the $$$ might suggest, the HE-4XX can almost keep up!
I have the Hifiman 5XX too, but prefer the slightly fuller sounding 4XX over it.
AUDEZE headphones in general have a significant recessed upper midrange / presence, that makes them dark and distant sounding.
I like my AUDEZE LCD2rev.2 (LCD2.2, the model with the least of this recession), with a bit of ADI-2’s equalizer.
AUDEZE of course is a different price range.
From Dan Clark Audio I have the DCA Aeon 2 Noire, a nice and open sounding closed back.
Strong bass, clean and uncolored midrange and presence, quite bright sounding, treble can be tailored a bit with the supplied filter inlays.
3 (edited by Jperkins 2022-02-22 17:26:19)
The LCD-5 has solved that for sure. They aren't cheap but I'm really enjoying working with them, as well as any casual listening time I can find.
The 2021 refresh of the LCD-X are also very good, and not too far behind the LCD-5.
Dan Clark Aeon RT looks good.
5 (edited by KaiS 2022-02-23 13:04:48)
Open or closed?
Make sure you have a return option, headphones are a very personal thing.
Maybe get one more to compare too.
Anyway, give it some days to get familiar with each one’s sound before doing a final decision.
