Topic: UFX II input 9-12 suffer from low input levels
My UFX II's input 9-12 (Mic/Line on the front panel) need significant amounts of gain to reach a reasonable working level, no matter used as Mic or Line inputs. The Line inputs on the back panel are all fine.
I compared the Mic/Line input levels with my old UCX and the difference is huge.
The unit I got is an used one. Since I rarely use Mic inputs, the problem is only recently discovered.
UFX II Firmware: v22 / Driver: v3.221
Does anyone have encountered the same problem? Thanks in advance for any insights!
