1 (edited by retrorack 2022-03-02 18:02:53)
Topic: MADI LC to SC cables
I recently purchased a MADIface Pro and Ferrofish Pulse 16MX. The Pulse uses the LC connector shape, and the MADIface the SC. I need a longer cable than the one included with the Pulse. I know RME sells the SC-SC cables in multiple lengths, but I only see one length available for the LC-SC cable. Does that one come in longer lengths as well, or do I need to go with another route? I mean, I could get an SC-SC coupler and an extension cable, or perhaps look for another supplier. Just checking this first.
MADIface Pro / Ferrofish Pulse 16MX
Re: MADI LC to SC cables
The coupler should be a good solution, then you can connect an ALVA MADI cable in whatever length you need.
Otherwise you'll have to look for a single cable from a fiber supplier, we do not have various lengths of this SC-LC cable.
That’s about what I was figuring. Thank you Jeff, I’ll follow up on that.
