1 (edited by Sparkl 2022-03-11 02:10:43)
Topic: DigiCheck sample rate
Hey guys,
is there a way to be able to open DigiCheck in 44.1khz? It seems that opening it locks the sample rate to 48khz and I can't change it. Problem is, I'm running Sonarworks EQ and switching to 48khz disables it since it is set to 44.1khz.
Any solution to this?
Re: DigiCheck sample rate
Hi!
In DigiCheck > Options > Audio Device Setup > Sample Rate
set/tick "actively" select 44.1 kHz press OK
regards S-EH
S-E Hansson wrote:
Hi!
regards S-EH
Thank you very much sir! I've literally searched the whole DigiCheck app and apparently missed this one function.
It works, thanks again!
