Topic: HDSP9632 freezes up on Windows 10 system. Please help.
I have an HDSP 9632 with a SPDIF breakout cable & a balanced lines I/O & MIDI I/O breakout cable. I'm using driver version 438 on a Windows 10 Pro system. Core i7 3.4GHz CPU, 32GB RAM, a 1TB Samsung SSD 860 QVO boot drive & a Gigabyte GA-Z68A-D3H-B3 Rev1.3 motherboard. I installed the drivers about 1 week ago & that went smoothly. I read everything I could find on the card installation process first, so that probably helped. I installed the drivers. Shut down & powered off my system. Installed the card. That took 2 hours because the card didn't fit in the PCI slot opening of my chassis. It got hung up on the breakout cable connector on the card. I finally had to get a big hammer & just pound the .... Ok. That's what I felt like doing. What I did was take lots of breaks & finally just did a little mod to the opening to gain the additional 1/4" required to allow the card to fit in the space requireed.
I put things back together & booted it up.TotalMix was installed, the driver was installed correctly I think. I didn't get any errors. I rebooted after the installation & TM & the info came up when the desktop loaded.
That was in the evening. I came in the next morning to find that I couldn't bring that system back to life. I only let Windows turn off my monitors. I don't allow my system to actually turn off any hard drives or go to sleep. I wiggled the mouse & pressed a few keys on the keyboard & nothing helped. I tried logging in via VNC from another system on my network & that didn't work. None of the other computers could see that one on the network, I couldn't ping it, so I could only press the reset button. Which I did.
At first the system would only run for a couple of hours before it would just lock up. I changed a few things in the BIOS & now it runs from a couple of days & then locks up. A big improvement. But not enough.
I checked on this site to see if others have had similar problems & there have been 2 or maybe 3 over the last 15 years or so. Thank goodness. If I would have found that this is common, I would have been kicking myself for not doing enough research before I purchased this. Oh, I forgot to mention that I just bought it a couple of weeks ago.
Also, it not only locks up my PC, after a couple of lockups the Totalmix software won't start & then when I look in device manager I find no traces of the HDPS9632 ever being installed. It's just disappeared. Last time, I reinstalled the drivers & things started working. This time, I thought it a good idea to stop here & see if I can get some help.
Anyway. If anyone has an thoughts or advice on my next move with this, I would greatly appreciate hearing it. Good advice may even keep me from just jumping up & down on my PC or finding the tallest building I can & tossing it out the window. I've been doing this a long time. I've had my eye on the RME products for a VERY long time. I finally decided to pull the trigger & purchase a few. I WAS very excited to try this stuff out. While it's working, it sounds great. I just can't keep reinstalling the drivers each week & powering off my computer without shutting it down ALWAYS makes me nervous. One day it just won't start again.
Sorry for the speech. I'm done now. Hopefully someone with provide a solution for me & I'll be back to recording... Thank you -b<
