1 (edited by brooksaudio 2022-03-16 18:02:22)
Topic: Totalmix 1.75 / Mac OS 12.2 / Workspace Quick Select issues
Hi there
Totalmix 1.75 / Mac OS 12.2 running on an i9 MacBook Pro 2019.
W shortcut opens the Workspace Quick Select view, but numbers on keyboard do not correctly select the slots inside, even using Alt and the main horizontal number keys.
https://www.icloud.com/photos/#08fsVOw4 … yRRuujxHlg
Re: Totalmix 1.75 / Mac OS 12.2 / Workspace Quick Select issues
I did not download that video, but it works here in an intuitive way. Hitting any single number jumps to that number. Hitting two numbers like 1 and 3 jumps to 13. Etc.
If you have hit 2 and now want to change to 7 you have to wait two seconds, then the second entry is no longer seen as belonging to the first one (27). Or use cursor down.
I did not download that video.
I made the video to show it doesn't work as you describe.
Then try this version of TM FX:
https://www.rme-audio.de/downloads/tmfx_mac_176b1.zip
That's what I used for testing with the 'horizontal' keys.
Still having problems with the horizontal keys.
Try recalling Workspace 1, then repeat the same W > 1 > Return again.  You end up with 10 instead.
6
I see. We'll try to fix this.
Thanks MC!
Now I have dual Stereo / Spatial workflows this would help me to switch quickly (using a stream deck).
Hey MC.  Did you get anywhere with this?
9
Not yet, but will come.
Thank you!
Hey MC
Do you have an anticipated release date for this bug fix please?
12
Sorry, no. Please note that the selection behaves like described since we first added it a decade ago. The fix is planned but does not have high priority.
Hey MC.  With respect the key commands definitely do not work as described!
14
Whatever - an improved version is in 1.77b1, currently available for DriverKit Beta Testers. A public version will be available soon.
How do I get on this DriverKit beta program?
I have found a workaround!  If you launch the Workspace quick select window (W) then hit escape to close it again, then open it again it works as expected.
17
You can use TM FX 1.77b3 without changing your current driver:
https://www.rme-audio.de/downloads/tmfx_mac_177b3.zip
