Topic: RME ADI-2 DAC FS and Hypex NCore final power amplifier
Hello I just got a RME ADI-2 DAC FS and I kindly ask you experts for suggestions. I write from Italy, forgive me if I use google translator and I state that I understand very little about electronics. I have a stereo, non-integrated power amplifier with no volume control and would use the RME as a preamp using its volume. The amplifier is in class D based on Hypex Ncore NC252MP amplifier module, fully balanced and with XLR inputs, so I would exit the RME in balanced XLR and enter the amplifier in balanced XLR. The characteristics I know of the amplifier are the following:
THD + N: 0.0015%
SNR: 121dB
Output noise: 30µV
Output Impedance: 1.5mΩ
Frequency Response: 10Hz - 50kHz
Input sensitivity: Maximum power at 1.66V RMS (2x0.83V RMS).
I was told that it is an easy amp to drive with DAC with volume control, but on a test done with a Chinese SMSL AO200 DAC I was not at all satisfied at low volume, they lacked a lot of dynamics and with inconsistent bass while turning up the volume of the DAC gave off all the quality of the power amp, this prompted me to buy the RME as I have read wonderful things and I know that it is configurable to make the most of the power amp. What I really don't know is how to do it, although I have read the manual and read many posts here in your forum. Some say attenuators ... who earns ... who automatic output level to be managed by the RME ... I am very confused, if someone kindly wants to help me ...
I have a room of 20 square meters and fairly efficient speakers, 91db, but I live in a condominium and I would like to have a good quality from the amplifier, especially at low volume, the one I will use the most.
A thousand thanks! Danilo
